Hi all..
Well... Not sure if you know, but car atm is running 7-10PSI, turbo back w/ hi flow cat, FMIC, stock ECU.
Ok setting scene.. Around 11PM, driving on M7, cold nite.
Car running 10PSI as a max on 39% duty cycle. Ive seen it only goto 0.69bar @ 6814 rpm once, in like 2nd or 3rd. (according to AVCR)
1st gear no problems, switch, backfire, 2nd gear no problems. So far so good.
2nd ->3rd, no problems.
1,2,3 all seem to goto 5.5-6.5krpm no problems.
At 4th it gets funny. When I floor it in 4th, around 4.5krpm or abit above, it starts to surge? or miss?. Feels like there is lack or power or not enough fuel or cylinders not igniting. However if I dont floor it it will happily goto 5 or 6 but slowly.
So question is, is this a fuel cut or the engine missing?.
Using NGK Irridum Sparkies ~30k done on em. Stock fuel pump. Stock coils.
This only recently happened when I put the AVCR in, ie. increase the boost.
Some say its the sparks, some say its the coils, some say its fuel cut.
What do you guys think?
Cheers!
https://www.sau.com.au/forums/topic/116565-surging-missing-not-sure/
my car surges when its cold and ya try and floor it.. but that im assuming is normal
i dont think it would be fuel cut unless you trying to get past 180ks. as for spark plugs.. could be a miss, but if its a miss, that cyl would cause a backfire every time, mine did that when i got a drop of water on one of the coils once and it would arc out and not fire the sparkie on boost.
check your sparks, make sure there gaped to the right amount.. think its 0.7 cant remember.
but thats all i can think of off the top of my head, i havent had any dealings with AVCR's
excess airflow protection is a violent backfiring nasty thing, so i doubt it is that.
gap the plugs to 0.8
check with other coils that aren't doing it.
my cars doing a similar thing and i know that is the coils, im running 0.6 gap to try and stop it, but it aint working anymore
try dropping the gap lower til it goes away, til you can get new coils.
Edited by Craved
Hi all..
Cheers!
Sounds like the duty of the AVC-R is set incorrectly
Thanks siksII, does look like a missing issue.
And Yea Craved, might have to check at regapping the current sparks.
Car isnt a daily driver now so its ok, though I would like to give it a bit over the w/e ie. missing would annoy me :/
Hmm... Maybe, ill play around with it abit... Though its set at 35% duty less than 3000RPM, then each 500RPM up it goes up 1%, untill 40% duty.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
