Know a few people that have vk- vl dunnydores and put RB25DET into them, they go like all hell, but seem to become a bore after a while, cos they are good for one thing, BURNOUTS.
but at the end of the day, a dunnydore running any other engine is still only a dunnydore.
Why the hell would anyone want to put a RB20 into a dunny, they rev harder, but produce no where near the same power or torque as a RB25DET... so i guess that is where my answer lays.
Tell him to buy a skyline.
grow up would ya?
each to their own, perhaps they like the shape of vk's, vl's etc
perhaps they dont like the shape of skylines?
gee's
its something different, good on anyone who wants to build a project car.
grow up would ya?
gee's
"each to their own" i clearly stated it was a bias opinion, i wasnt trying to give him shit
Nothing against people that want to do a project car, but what has been posted that he wants to do.. that sounds a little bit stupid.
I would say to look out for a good RB30 turbo block and track down a good RB25DET head, and go a little hybrid, they seem to be a little better in the commodores.
I only suggested a Skyline cos that is what the engine that he was looking at already has from standard.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
