  • Replies 513
Posted Images
Satanic is a definite (hopefully all the goodies will be in by July 2) - time to test this thing out :thumbsup: *nudge* Adam *nudge*
NBP Team may have 2 other entries; another from SAU and 1 from RENEW.
immm in! as long as i get my suspension troubles straightend out! but july is verry far away so all good :thumbsup: now to get the cams thing done
ohhh btw i got stuffied coilovers... rekon i shud go and do the track day wid stock suspension instead?!... or would it be more beneficial to change em?
thanks!!!
Guys and Gal's,
Definately go to this one if you're one of those "I'm worried about my car getting wrecked" types. this has to be one of the best beginner tracks around!
Unfortunately wont be able to make it as I will be in Italy at the time..........but have fun!!!!!!!
holy shit its far......2 hours drive....so to get there at 8 in the morning I'd have to get up at 6:30.....ARRGGGHHHH
2 hours drive
get up at 6:30
earliest you would be there is 8:30 lol
unless you speed.. and I dont recommend speeding around there.. Ive been fined each time I have driven to wakefield.
Adam.. I cant afford a track day so do you still need a flagwhore?
Abo,
Are you coming? I look forward to seeing both of us improving our times, and I would love to do a head to head again.
If things work out the way I plan then to, I should have my Cam sprockets in and the 100 ron tune completed. I will probably boost up if I get this work completed.
Sam very keen to have you there. James - yes it's a big big day out but it's so fun you wont care.
Paul - Of course I'll be there. I'm still tossing up whether to do my secret mod before then or not so I may be able to keep up with you... we will have to wait and see.
Cefiro - CHECK
RB25DET - CHECK
SEMI SLICKS - CHECK
NEXT TO NILL TRACK EXPERIENCE - CHECK ;)
Should be interesting.....ahahaha
At least Wakefield is most prob the best track to get used to the car on!
Fun shall be had.....!!!
Question, what type of facilities will they have there for us? Will they be providing power? The boys will be trucking along a full tool kit and we're thinking about lugging along a generator if we don't have power >_<
Stan, you can hire a pit garage if you want, i think its $50 a day - not 100% sure though
Try calling wakefield during normal hours, they will be able to tell you about power in the free pits(carports).
The number is all over www.wakefieldpark.com.au
...so they will have air tools? Like to take rims off? That may be handy >_<
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
