WOOOHOOOO IM IN!!!!!!!!!!!!!!!!!!!!!!!!!
d00dz --- 1st Time
Primordial --- 1st Time!
nath95
R31deviat --- 1st Time - SLOWer than Liz.
Stolly
D_I_F --- 1st Time
Sh@un ---wasnt timed first time there, did 1.27 at OP GP (he cant get to a computer)
satanic --- 1st Time
yogi000 - been before, but never timed
Oz GTR02V --- 1.12
godzl1975
tuitahi
lingering soul ---- 1st time!!!! YEAH GONNA OWN U ALL!!!
  • Replies 513
Posted Images
d00dz --- 1st Time
nath95
Stolly
D_I_F --- 1st Time
Oz GTR02V --- 1.12
godzl1975 ---1st timer
tuitahi
d00dz --- 1st Time
nath95
Stolly
D_I_F --- 1st Time
Oz GTR02V --- 1.12
tuitahi --- 1st Time (and so are my other two places)
Abo,
Do you think we will be able to take a couple of car loads round for 2-3 laps at the start of the day? Aaron McGill does this with his days and it normally helps the first timers a lot. They get to see what a skyline can do and roughly what gears and pace they can do around the track.
I find it normally slows down the hoons and gives the first timers some confidence to go a little quicker.
Let me know your thoughts.
Looking forward to the head to head battle again!.
Hows your secret mod going?
I am having my cam sprocket's and 100 Ron tune done this weekend, it will be interesting to see what difference this makes in the real world.
Abo,
Shotgun! :D
Oz GTR02V,
WRT to the first timers, RENEW will be running the day in a similar format to our previous days. ie a first timers familiarisation session at the start of the day.
Craig
Craig, last time we did it one on one and I think there were some people that missed out. With this many first timers it may take some time to get through them all. My suggestion was to have 3 passanges and do a group run as per the Aaron McGill days, I find there is heaps more questions and a better flow of info when you get a couple of people in the car. In addition every one gets a good look at the track, gear selection and line.
Your thoughts?
Your thoughts?
Hey Paul,
If Wakefield Park allow us to do this we will consider it, if not we shall stick to the current schedule.
Cheers
Nathan
Received your forms tuitahi :D
Will keep an eye out for yours lingeringsoul and R31deviat if u can get yours thru as soon as u can :rofl:
Another newbie question...
Do we need a battery location sticker?
It is not a requirement for Wakefield Park, but if you are likely to attend further events that are CAMS sanctioned it will be required so it doesnt hurt to have it.
RE: Semi Slicks
These will give you 3-4 seconds a lap improvement over street tyres at Wakefield park provided everything else is up to scratch including the driver :) Certainly not necessary to cut some decent times and still have a great time :D
Lots of 1st timers, you boys and girls are going to have a ball :D
Waiting on entry forms from the following;
A31deviat
lingeringsoul
Kevin Leung
David Montauti
Um forms??? Huh?? I sent mine! :)
Oh hangon on seacond thought that was Wakefield.... ahahahah :D
Will search for the form and get it done asap
Oh and its A31Deviat... sif drive a R31 Skyrine........... :D
Cefiro baby, don't you forget it :w00t:
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
