  • Replies 513
Posted Images
nah, they couldn't fit me in this week, so I took it to UAS instead. They ordered the barrel today and will arrive tomorrow for fitting.
Suspension is getting changed as well, along with a quick tune.
The only little thing left is the steering wheel, might just have to use a tape to tape up the part the thieves cut and hope no one notices.
ATTN LINKS, I may be going down to spectate on sunday.. ill know tomorow , and if i do ill be heading down from the central coast so i could meet you somewear allong the way perhaps
Regards
Dave
Edited by r33freely
just a quick one....
are we fortunate enough to have numbers provided for us again like at oran park???
thanks
George
I dont think so. Read a few pages back on this thread, I think I asked about it. And Adam (Nath95) said to do what he did ;) so Ill just do that.
Guys, i will take care of numbers for you all if you like
Be prepared to have some sticky tape on your doors to hold them on (doesnt leave marks)
I can laminate an A4 sheet with the number on it and just attach that to the door on the day :kiss:
Let me know and ill do it today after work
Up to you mate
Just thought it would look better if all the SAU'ers had decent looking numbers(looks better in the pics that will be taken), and they were easy to read, unlike a few at Oran :kiss:
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
