  • Replies 513
Posted Images
Hey steve, could you do mine number too, 81 there's a beer in it for ya!.
Yeah its already done, i just couldnt be bothered laying them all out for the photo - ive done one for everybody from SAU
Cheers for that Steve-0 :dry: Champion!
Just incase you didnt know? I drink scotch :D
Ok, so i had to take a call, and it took more than a minute
And so on for the others (couldnt be stuffed covering the floor with EVERY single one)........
So thats one less thing you lot have to worry about :dry:
Thanks for that!
Some final info will be posted up soon, mostly for the 1st timers but you will all need to read it.
Scutineering starts at 8am and finishes at 8:45am if you dont get your car done in this time period you will need to wait until after the drivers briefing.
Woot! Looking forward to this foshizzle... been doing some servicing the last couple of nights so the car will pretty much be fresh (belts; fluids; all filters).
New tyres go on today :laugh: Not expecting any super-low times as I'm not running any boost at the moment :D But will be a good comparison for next time when I do go back with boost (hopefully) :D
why no boost?
soo!! may be heading down on sunday.. i vaguely remember the way, but does anyone else have street names/directions?! :D
Easy, once you're on the highway, take the Goulburn exit, then follow that for a while, you will cross a bridge, turn left at the first set of lights after the bridge, follow that for a while. Go past a pub and some shops, then there will be an UNDERpass of the track tracks - ignore that - you want the OVERpass which is on the left (theres a sign) go over the tracks there and follow that, then just cruise along until you see a racetrack on your left :)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
