  • Replies 513
Posted Images
Yeah Mitch and I were sharing the day - car took a complete pounding as he was in Group C and I was in Group D. Car had no issues (apart from having no boost :nyaanyaa:) but the temperatures were getting a little bit high and uncomfortable by the end of my sessions.
Don't really know who got what times per lap; but Mitch's best was 1:17 and I was slower with 1:19.
For Eastern Creek we'll just keep to the one Group and let the car cool down properly instead of having it go in one group after another :D
Car's going through some TLC at the moment so it's all good :nyaanyaa: And by EC I should have the rest of the gear put in which will make it a whole lot more fun :)
Question to all the seasoned pros out there: If you were going to get serious about the track day... do you go out on every session to get maximum number of laps in, or do you set yourself a number of laps to 1) reduce damage to the car and 2) do your best in those laps.
I'm thinking... going out every session and gunning around the circuit is not only going to be pretty harmful to the car but also on the wallet for fuel :laugh:
James; we left early because the temps were getting a little high yes. Also because we wanted to raise the suspension, but didn't have C spanners to do it with (forgot) so we just settled for that time and packed up.
First time Mitch or I had been to a track day; we went not expecting much; only to see what the car could do. Now we know, we will do what's necessary to make it better and hopefully in the meantime improve on driving skills :)
To Adam; you are right - these are addictive!!!
I'm thinking... going out every session and gunning around the circuit is not only going to be pretty harmful to the car but also on the wallet for fuel :)
I do the following.
The first session I do 3 warm up laps, get the enginee, brakes and tyres to track temp.
All other sessions I do 1-2 warm up because the car normally still has some temp in it.
Always do 1 SLOW lap cool down and keep the car running for about 5min.
Never do anything more then 10-15min (Summer-Winter) at full go, a street can cant take much more, Brakes and tyres go off and enginee temp gets too high.
Saying that every car is different!
Thanks for that advice Paul.... from that it would seem that our strategy from now on is OK, no more than 1 session at a time.
I think the rather high temps were in fact due to us running in consecutive sessions :)
just buy a rb30 powered silvia
and just thrash it session after session
it loves
you know what? when I get my debts all paid off in a couple of years, and the price of S13 drops to rock bottom, I'll get myself a banged up silvia and use that as track pig. hehehehhee
I do the following.
and leave your handbrake down for that 5mins :blink:
and ouch! massive crack!!! awesome effort! lol! :)
A few of the guys with Group Buy suspension kits have asked if I can make it to the next track day. So when is it, so that I can lock it into the calendar? Eastern Creek, is that right?
:/ cheers :O
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
