OK
Im going to base it on the R33 airbox, and get a snorkel made up to suit that. ie itd have the same funnel opening into the airbox, but the funnel opening at the front of the car on topof the engine bay will be HUGE. Might look silly, but it'll surely get some air.
With the template one, I'll have to bend it or something to make it fit the stagea (due to maxx's cai unit being at a slightly different angle compared to normal. But thats all good. From then, I might offer a group buy or something on them? Only drawing board stage but Im sure 100 SAU forum users out there with standard airbox's might want a 'ss induction' type snorkel air feed.
:nyaanyaa:
https://www.sau.com.au/forums/topic/117310-cai-box/page/2/#findComment-2218867
What about the radiator cap??? hhmmm silly me. :D
might not be on such a grand scale as I presumed.
pretty much a tube made up like a standard snorkel but with a custom fit and an air intake opening as per the space available, or hack at the standard snorkel adding metal fabrication to join it to the cai enclosure.
doh.
although a clone air intake opening with a joining piece on the other side of the radiator is a possibility......... !
Edited by Tangles
https://www.sau.com.au/forums/topic/117310-cai-box/page/2/#findComment-2220496
well, a nice neat job.
Didnt do my idea above ^^ (yet - maybe sometime ya never know)
Utilising standard R33 snorkel (machined edge of radiator support metal bracket), moved the boost bracket, and filed a little metal to clear the afm wires neatly.
You can see the blue line where I was going to cut to make it fit, but it was all sorted and all fitted well - with the extraordinary efforts of Pete (66 Skyline GT), thanks mate.
Gave Pete my rb25afm for his RB20det 66 Skyline GT, a good deal. His car is a 'wee-rippa' for sure, 140rwkw weighing a tonne. :P He's also might be able to help me with extending the seat brackets slightly. :) that'll be awesome!
So - Maxx's cai for R33/R34 skyline does fit as is, just a tiny touch up needed to suit the Stageas. Going to finish it by adding heat-foam stuff stuck to the inside, and that'll help close the little air gaps etc. (edit: painted the lid black, looks sorta stock lol, and bought a heap of heat-insulated foam for $10)
and a pic from outside (cant see the cai LOL but you can see the nice sorted suspension) :D
edit: oh yeah, flows lotsa clean cold air, can tell that prior to this cai install the k&n pod had been sucking engine bay air. Safc now needs a slight retune lol although very minro, that can wait now for the larger turbo.
Edited by Tangles
https://www.sau.com.au/forums/topic/117310-cai-box/page/2/#findComment-2225200
Any power difference at all do you think Brendan?
well, Im sure I could feel a 0.8% gain LOL
in fact, if the car had Bass Junky's radiator guide installed, and had the safc/sitc retuned as is now, Im sure itd gain an extra couple awkw above 4600rpm in 2nd gear - felt a new 'slight hesitation' there.
Im200% positive thatd be because more (however slight) denser cool air is going thru the system now meaning at one point in the higher rev range the air/fuel mixture is out slightly. A good retune would surely yield a couple more ponies, however its all a waiting game now until the forced induction 'flow' is increased :)
edit: I really like how it fits into the engine bay - looks good.
Edited by Tangles
https://www.sau.com.au/forums/topic/117310-cai-box/page/2/#findComment-2226432
OK - update.
sucked down half a tank of fuel in 150kms, so it looks to me as if right atm, the airbox is supplying too much air, and Im losing over 20kms per 1/4 tank of fuel.
So, got heaps of air coming thru on boost, so my safc is now saying throw in heaps of fuel..... need it retuned I guess, but have to wait until Ive got the cash for a hiflow.
https://www.sau.com.au/forums/topic/117310-cai-box/page/2/#findComment-2241778
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
