Hey
Anyone want a free rb25 bottom end? I suspect is has f*kt rings, but i havent really had a look, i started to open it up but never got round to finishing it as i used the head for a rb30det conversion. I has pistons, rods, crank, block and sump. Thats about it, no oil pump, no water outlet fittings and no head.
If no1 wants it, ill take it too the dump.
My number is 0413 032 208 and the motor is in hurstville
thanks
-Tom
Edited by kossak
https://www.sau.com.au/forums/topic/117744-syd-free-rb25det-bottom-end/
