gday just wanted to know if anybody knew what lsd fits the oz delivered r30 hatch??? any info would help cheers :thumbsup:
R180 & R200 Long Nose Mechanical LSD's.
The R180 you might get from the front 720 4WD Ute, the R200 is the best but is also the hardest to get.
You need the half shafts as well with the R200 as it's bigger in dia, hence the shafts are shorter AND thicker.
Good luck on finding an R200 to suit.
The R200 from S13/R32 does not fit or suit.
Cheers, D
https://www.sau.com.au/forums/topic/117952-lsds/#findComment-2169535
I belive that the front LSD R180 Diff in 720's were a factory option, as were the rear Lsd H190 diffs.
They are hard to find, Possibly harder than a R200 LSD.
There are aftermarket/Nismo Lsd eqquiped R180's, but these usually sell between 1k to 2k depending if its be rebuilt and what gear ratio.
(Im still trying my luck on getting a reasonably priced one for my 1600).
Hope this helps.
Cheers,
Dan.
https://www.sau.com.au/forums/topic/117952-lsds/#findComment-2211648
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
