Sorry i couldn't seem the find the answer in the FAQ's
Basically i am after a set of Stock Stagea rims the 16x7? 40 offset rims to cover r33 gts m spec brakes
The mesh style is the type that i seen on the cars and i am wondering if there the same internally diameter dimensions as say a r33gts rim , or a r33gtr rims clearance wise .
stock r33gts rim with the r33 gts brake caliper
Thanks
Adam
Standard Stagea S1 rims won't fit on the front of R33GTST's, the spokes hit on the callipers. They fit on the rear OK though. I tried it last week for the drags, as we have the MT ET Street radials for the rear mounted on the Stagea rims.
:D cheers :P
Sydneykid
Would you say that say 5mm spacer would fix that problem ? I am using s13 struts with s14hubs and for the r32gtr rims to clear the strut i have had to machine a bolt on hub spacer of 20mm . So there is 20mm extra caliper spacing over the caliper from standard due to all the r32 rims being for a wishbone front end .
Goldzilla
Yes that is a gts wheel on a ae86 . The front brakes used to be sr20det 280mm ones for many years , but since going to very modified s13 multi link rear i have decided to convert all the brakes and stud pattern to 5x114.3 to make finding rims easier . Finding 7.5 - 8 inch rims in 30-40 offset in 4x114.3 is next to impossable now . Is basically a 86 body now there isn't much left thats not nissan or from some other make.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
