remote Breather tanks for radiators ..
already running a PWR 40mm radiator but she still bubbles a little after getting hot ..
are kits like this useful on systems that already run header tanks with the presuure caps?
only ever seen them on sealed cross flow units..
any ideas??
https://www.sau.com.au/forums/topic/118629-remote-breather-tanks-on-radiators/
Hey Chris,
I got one of these installed; main reason for it is to remove air locks which it is doing just fine.
My tank is setup where the stock charcoal cannister is and does the job pretty well!
NB: There is a T-Piece that you require in order to make the product you've shown work, it's not included!!!
S
oh, i thought u already had one. how come the plenum now stops you from bleeding the cooling system?(never done any cooling system work on 33's maself) i cant really see how they would be of much benefit on a system that already has a header tank with pressure cap though.. basically, they do the same job. does the factory header tank have any form of 'breather'? if not then this might do sumthin for you
Hey Chris,
S
hmm would like to see how its hooked up, cant really picture it... does it pull a water feed from somewhere like where the std water bleed is?
the front facing plenum relocates the TB, and since it dont really snow here i didn't run the water feed through the throttle body .. hence its removal..
Edited by Craved
The tank is situated in between the overflow tank and the radiator... in total I think there are 4 lines coming off the thing, 2 going back into the radiator (well one from and one back to)
The other hoses then go to the over flow and one has a one way air bleeding cap (trying to be descriptive)... it lets air out but not coolant (?!?)
Not 100% sure, the boys put it in and said it works :wave: I'm happy and was content with a 80% understanding :wub:
hahah once i see it i will get it fine..
can see where the return from the tank to the radiator would enter the cooling system as the pressure cap on the radiator wouldn't allow water back in very much.
got a picture Stan?
bleeding air from the system is extremely important - more so than people generally think. air in the cooling system is a killer and will turn the block into a kettle - particularly when we have lengthy 6 cyl engines and there is a significant temp differential between the front of the block and the rear as the water from the radiator only enters at the front.
some aftermarket chevy heads now have cooolant take offs half way down the side of the head for that reason - more even core temp means more consistent combustion and more efficiency.
the breather tank is probably a good idea in a high hp engine, one that operates at higher temps for long periods or one that has no bleeder :O make sure it's at the highest point of the cooling system otherwise it just acts as an extension of the water jacket and, instead of turning steam into condensation will recirc the steam.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
