Just purchased a Garrett GT3540 (GT35R) for my R33 GTST. pulling off the old HKS GT-RS turbo for some more power :nyaanyaa:. the turbo is rated at 700hp and i have it with a 0.82 rear housing so boost comes on reasonably early. Has anyone seen one of these on an R33 gtst?
Also motor is standard internals, only have bigger cams. Anyone else running 320+ rwkw on the standard motor? How long have you been doing this for?
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/
I had put one of these on my r33 , great choice. I wouldn't run it on a stock internals but thats just me being safe.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2184377
Im running a 35/40 .82ar on my 33, power fc, z32 afm,38mm external gate, pump injectors, fuel rail, plenum, zorst etc. 289KW on 16 psi. Standard internals. Cant run anymore boost (std coils) The tuner said it will get over 300KW easy with splitfire coils. Sorry cant find the dyno graph.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2185526
my car has been making over 350 kw off the standard motor for about 5 months now
i have run a 10.8
and have done endless hours on the dyno
and i mean over 350 dyno passes
trying different pleniums,fuels,boost controllers,coils & different power between clutch fan and thermo fan
as long as you have a safe AFR and large flowing intercooler such as a garret core 600x300x100 it will last.If you have a lean AFR and Small intercooler 600x300x76 then it wont last as long.
with nitrous my car is making over 400 kw now
its making a total off 591 hp at the rears.Hasnt poped yet
i thought ill put these motors to the test
and they are pretty much bullet proof.
the problem with RB motors is if they detenate in top end revs or oil surge its the end of them.Always maintain good oil and Fuel
Edited by MR331307
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2185608
I have a 3540 with .82 exh housing on my 33 and it's on full boost at about 4500rpm. On 15psi its making 306rwkw on standard internals (apart from cams).
Can easily make a lot more, but I dont want to break the motor just yet :P Running quite conservative on A/F ratio at 11.2 to stop it leaning out anywhere.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2185688
mr331307 ya makin 400kw with nos on a standard engine?? but i see ya car for sale and it has forgies ported head gtr rods the list goes on..thats not exactly standard man or is that a diffrent car???
sorry for hijackin ya thread boro but i might have to try a shot of nos if 400 is possible
Edited by thizzle
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2189473
Nah its the same car
just my car still has the standard motor in it
and the person who buys the car gets the Race motor i have built
Currently im running 18 psi in it with a 50 shot of gas and its made a total of 591 RWHP on my dyno. Inlet temps just under 40 degrees on the dyno sheet.
I have done that many things to this motor and it wont blow up lol
i am going to run 24 psi and 75 gas when i come out to see if i can run a 9 if it blows then the other motor goes in and ill run 28 psi and 100 shot of gas.I want to see if i can achieve a 9 on the standard motor.
the car is for sale so if some 1 wants it PM me and stop hijacking the post
Thanks Jason
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2190344
And if you want dyno sheets of my car without nitrous
check ou t
MAX HP out of standard RB25 motor
Heaps of dickheads posting shit on the thread but bypass what they have said as they have never tried or done research in the making power out of these motors.
I thought i will give it a try and its lastest me over 5 months or so now and i dont mean grand ma driving
I drive it like i stole and and off my Videos on my site you can view it in the burnouts on limiter.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2190367
im sure croat wont mind me askin questions were good mates..
mr 331307 i have read ya thread and if ya check i actually supported you when others cried bullshit..it just 400 is gettin a bit hard to swallow on pump fuel..was askin cuz as i might try a 50 shot and see how it goes..
have u opened the engine???
what brand is your dyno? keen to see your next result lol maybe youll hit 800hp
Edited by thizzle
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2190407
nah havent opened the engine yet as i quoted completely standard with 69000 kms on the clock.
if you are located in NSW i am more then happy to put the car on my dyno which is a dyno dynamics Shootout chassis dyno and show you the cars RWHP.I will also show you and take you for a drive to show you its on the pump fuel.
In total im making 500 HP on 18psi and 591 with 50 shot of nos on pump fuel & full exhaust.
i find that over 18 psi you will need pump fuel as there isnt enough octane to suit hi combusition & temps in the engine.
Im pretty sure you can watch the first stages of the car on the dyno from that site.I will upload the 10 sec pass soon as well as the 550 + dyno runs.
You will find that The Intercooler,The Tune & the Plenium all make a big difference in the motors Power.I have done alot of reasearch and have found what works and what doesnt.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2191329
I made over 330rwkw using fuel on stock coils for over 6 months without an issue.
There are just some places will have you believe that you "need" to upgrade just so they can make a fast buck.
Just making sure ya werent being lead on :)
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2191750
Very true
i have dynod a car that made 300 KW with standard coils and its still going
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2191761
They are well overdue for replacement, but ill get a few more months outta them.
Yeah true that, they always trying to sell you something you dont need. I learnt my lesson the hard way with that.
The tuner only tuned cars, he does no workshop work, so i knew that he wasnt trying to rip me off.
Cheers anyways mate.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2191827
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
