yer, it AVWG
as for them not being worth the paper they are written on
i easily got repairs worth more than i paid for my warranty, so it was worth it for me
all they ask is that you service teh car regularly, which you should be doing anyway
even when a non certified mob did some work that was covered under warranty (replaced the engine fan) they sent me a cheque to cover its cost
i was pretty happy
Edited by Spook's_Skyline
