  • Replies 277
Posted Images
just the reporter asked me if we were all in skylines and what we were doing and if they were all turbo and what turbos do and shit like that.
she was being a retard.
just watch chanel 7 at 6
lol and also i didnt get ne money. i wish, i would of givin it to da families.
all the best
glad to hear drew is going to make a full
recovery, and hopefully jasmin does aswel.
also just thought i'd say, i'm glad i went to
church with steve.
i'm thankful that the festiva missed us
but at the same time i just feel like i
shouldn't be here.
Hi Steve
Could you phone (0413 648 750) or PM me if you have space for 1 passsenger and are passing through the city on your way to FMC. (I work at Womens & Childrens Hospital, but rely on public transport during the week)
Guy
Edited by 4door_Sleeper
Hey guys, we just got the news over at antrx.com (http://www.antrx.com/smf/index.php?topic=10706)
and on behalf of members of the club, we want to wish drew a speedy recovery and would like to pass our condolences to the driver of the festiva...
Good to hear that Drew and Jasmine will be ok.
the news report wasn't blaiming imports which is good as they named our club. I was a little worried after reading the paper this morning and they made a big deal about the "four Nissan Skylines"
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
