Lake mountain run
  • Replies 41
i'll be in.
get the GTS-R back on Friday (hopefully)
might be able to score an RDO for a week day...
excuse my ignorance... but where is Lake Mountain?
get up a more definate date so me/others can work around it.
cheers ash
https://www.sau.com.au/forums/topic/11893-lake-mountain-run/#findComment-210155
Guest ylwgtr
So far there is a T88 Thrusted supra and a couple of 180sx's...no other skylines yet...i will keep you posted as to when its gunna happen...in regards to the licence thing i have had it on and off over the last 6 or so years...although i lose it again in a month... you prob didnt see the car at the shop as lots of people borrow it from time to time
https://www.sau.com.au/forums/topic/11893-lake-mountain-run/#findComment-210222
i wont be able to make it during the week.. but me and a few mates are going on sunday most likely... if your interested let me know.
I rekon dont waste your time on lake mountain, do reefton, and black spur, then when in healseville head up towards Mt Donna buang.. its awesome.. even if it says summit closed, still go up, it will be open and no cars..!
https://www.sau.com.au/forums/topic/11893-lake-mountain-run/#findComment-211319
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
