Hey,
my headlights on my 93 R32 are really poor, meaning they arent really bright at all. now my problem is that i cant find what type of glob i have and ive looked everywhere, well nearly everywhere and have had 2 resort to asking. ive searched everywhere aswell.
From wat ive seen my globe has a H1 top with a three prong plug similar to the H3C plug. Ive taken the globe to a few places including repco and supercheap with no success in finding the right one.
does anyone know which one it is?
thanks
stephen
https://www.sau.com.au/forums/topic/119093-headlights-driving-me-crazy/
How are your head light covers? most plastic types eg. R33 tend to fade and form an oxydation layer.. if your head lights seem dull, try to apply a mild cut/polish onto them and let it dry... then buff hard with clean cloth
Hope this helps
best stuff to make your headlights clear again is mequair's scratch-x. i used it with a buffing pad on a drill and it took 10 seconds per light. and it doesn't matter if you get it on your paint as its actually made for paint. even by hand it works well, just takes a bit longer. i did the first light by hand then thought "bugger this, i'm getting the drill". as for the bulbs, take a pic of them and post it so we can see, as i'm not familiar with the r32 lights. but i know that r33's have h1 for both low and high beams. by what you have described they could be a variation of the h4 bulb. it is still classed as a h4 bulb but is smaller. or they could be a h6.
http://www.narva.com.au/Globes_15.html
have a look through there (at all 6 pages) and see if any match. you will need to take one out to measure it.
Thats interesting since H3Cs have a 2 prong plug. Maybe your thinking of H4s with the 3 prong plug.
From what i've heard the earlier R32s have H3Cs and the later cars have H1s. My R32 had H3Cs and i couldn't find any decent globes so got a set of philips H3s and modified the wiring to suit. The lights are still not that good but it was a huge improvement over the original globes.
In a 93 i would have thought you'd have H1s.
Gday Mate,
If you have the same problem that i had, i'm guessing its your low beam globes. Your right they are HC3.
dw i went too all the major car places (repco etc) and found them pretty useless.
You have acoupple of options like HID kits or replacing the light assembly but its much cheaper to just get more powerful globes, the ones you most likely have are i think 55W from memory.
If you go to this page - http://www.suvlights.com/index.php?cPath=42 - and have a look at the 85W Philips HC3, they cost around $17 American each (they ended up around $50 Australian to get em' to Victoria).
They are a big improvement, but by no means brilliant :starwars:, worth having a look.
Cheers
I think you may find out you get a voltage drop. Check with a multimeter the voltage on the wire that powers the globe ( with lights on), if you drop to say 12 volt or less run a thick wire to the lights and use a rely to switch it on. You will notice the difference when you have 14 volts there it will be like daylight.
how do the globes like being powered by 14 volts though???
do you find they will blow out more often??
No, why would they, if the electrical system works well thats what you should have .. Even the battery has around 13.8 ( fully charged).
possibly since they are stated to run on 12V and they could have issues at higher voltages
Check the voltage on your battery, if its healty it should be around 13.8 then start the car, it should be above 14 volt. Of course the globes will last a lot longer if you only put 6 volt through them but you will have very little light.
yeah i understand the volatges etc .. just if your your burning the element hotter at a higher voltage, i would be expecting their lifetime to be reduced as well..
just weighing up the extra brightness with rewiring the lights etc, to just installing the 60 or 70 watt globes to start with.
Even if you used 100 watt globes they wont be as bright as the 55's because you still have the problem (voltage drop)
jerry, i used to find that my globes blew a lot more often after I redid the wiring. I did it properly, nothing wrong. Was fused, relayed everything. I went overkill on the wire. The core was 3 mm. hahaha.
I was getting 13.8 v at the light. before the mod, I was getting 12.2.
I would not install a globe of higher wattage than what is recommended from factory.
I have experiences from 2 separate cars where 100 watt globes have stuffed the headlight:
car 1 - lancer. melted the wiring plug. also caused the reflective stuff from the headlight to peel over the course of about 6 months. The car was brand new.
car 2 - r32- caused the projector to 'go off'. It went from being cloudy to clear, and the light that it put out was about half of the other projector.
I personally wouldn't do it.
Let me guess, Chinese globes? They are crap. I had German globes at home ( 12volt downlights) , after 10 years use some started to go. I bought a pack (10) chinese globes because they were only a couple$ each ( the original German globes cost me about $10 each) to my surprise the new globe burned out after about a month!!
I did a re-wire job on my old 33GTR, i also made it so the low beam stay on when i switch to high beam, very bright light and no problem burning globes. Don't forget they are designed to work with the cars voltage ( about 14 V), when wires get old and corroded they have more resistance so you have more voltage drop.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
