The Fast & Furious style "smoke" is actually made by purging the nitrous lines. Hook a nitrous bottle up (illegal here, not sure where you are), with a purge valve coming out behind your bonnet which is activated by a button. You can load up the lines by opening the bottle, then purging the line by pushing your little button to activate the purge valve, and the nitrous will vent to the atmosphere instead of the engine, and create a nice little cloud. My mate has a similar setup on his big block Monaro.
yep,here right hand drive vehicles is illegal, we used here in converting it to left hand drive, like my honda ek4, just finished converting the other day, i put the skyline on the last...because this is the only first gtr here in our place...and the people who convert haven't work with skyline before...so thats why i want to start it after all my cars are finished so i could work it slowly and surely.....is there any tips guys??
I honestly don't think you will be able to convert a GT-R to left hand drive due to the layout of the turbos and the ABS (to name a couple of items that come to mind).
Would really like to be proved wrong, however! Good luck and post pics if you are successful!
Cheers
Gav
Cheers
Gav
They have done in the USA..
You're right - found the following link
Left Hand Drive GT-R
Got me thinking now - a GT-R in Bulgaria (crap roads 'tho!)
Its not to far to drive to Germany, perfect roads and no speed limit there .
I thought you could register right or left hand drive there ...
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
