hi guys, i was wondering if upgrading my fuel pump, make any changes to the way my standard r32 drive .?
i know i might be able to find an answer to this, but when i search the word fuel or pump nearly every post comes up itll take for ever.
if someone could be kind enough to just let me know. my fuel pump is on its last legs, i dont know if i should change it with a better one or just replace it with a stock one.
cheers!
https://www.sau.com.au/forums/topic/119245-fuel-pumps/
If it's on its way out and you aren't planning on modding where it needs more fuel (i.e. running more boost, upgrading turbo, injectors etc) then you won't need a bigger one. Just replace with a stocker.
On the other hand if you're going to upgrade other things that require more fuel later then get a nismo/walbro/whatever brand you like.
https://www.sau.com.au/forums/topic/119245-fuel-pumps/#findComment-2197058
if you go for an intank pump there are plenty of options walbro are cheap and i have had good experiences with them also bosch 040 and 044 are good pumps. i wouldn't bother with another stock one i dont know many people who haven't modded their car. as to what it will do to driving the car providing the pump is installed properly it wont affect the car
https://www.sau.com.au/forums/topic/119245-fuel-pumps/#findComment-2197558
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
