Originally posted by Boxcar Racer
my mate went all slack on me, where do you live 2fardown? are you going?
if so pick me up and i will come.. otherwise, it will just be me sitting at home,, remembering them from livid 99 and vans 2002 god dam they are good
I would go but i live in Mackay NTH QLD. :)
I also went to Vans 2002 at the gold coast...it was awesome..saw my favourite band New Found Glory.
https://www.sau.com.au/forums/topic/1193-stock-rims/page/2/#findComment-26647
