1995 Gtst Coupe In Excellent Condition With Low Kilometres
5 spd manual
Perfect car, drives well, pretty much stock standard with the exception of a recaro seat.
Wheels will be standard R33 GTsT items.
Car has just been complied and is in perfect road worthy condition.
Looking for a reasonably quick sale so offers are welcome.
Clean car that will be appreciated as such.
$16,800
0414561121
Edited by rb31
How low is low km?
And any other pics of interior? especially handbrake boot and steering wheel to show any wear.
thanks
Haha are you kidding?
I just bought brand new handbrake and gear boots... does that mean my car has low km's?
:dry:
No and I wasn't implying such. :)
Do I really need to explain myself? :ermm: Of course I know how easy it is to change gear and handbrake boots. Steering wheels can be swapped too, if one can be bothered. I believe the steering wheel on this car is the original, however.
Handbrake/gear boots are a good indicator of actual milage if still original. And if replaced, still a good indicator that the originals were worn. Hence, no, I was not kidding.
Anyway, sorry for the off topic post.
rb31 - I initially overlooked that this car was in Brisbane, sorry for wasting your time. Very nice clean example of a Series 1.5 R33. Good luck with the sale!
I am interested but not at the price.
I’m not saying you need to agree with me.
Don’t want to waste your time so I’ll just say that I am looking at spending $12K and if that suits you, then let me know.
If not, I will just buy one of the ones on carsales who have had their cars listed for sale for many months.
Not fussy of 93 series 1 or up to 97 series 2.
Also don’t care what colour I get all that much.
Just need an R33 and will spend up to $12K in the next week to get one.
Not a time waster or tyre kicker.. just sold my car and looking to buy another.
Cheers
Not interested at that price.
Cheers
Cheers
Cheers
good luck with that i hope u get ur self a nice non turbo or an auto or maybe somethin with half a million ks
good luck with the sale man i wouldnt go under 15,000 very clean example
Edited by CU-LOOZ
Cheers
Open to reasonable offers. Best offer above 15K and I will let car go.
Cheers
and how much did you sell yours for?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
