meh it did them all minues one, dunno why it wont resize that one
next job is to send the 30 block and 26 head off to john, and the clutch off to jim...and in the meantime i can get stuck into cleaning up the engine bay
so who is doing ya rebuild?? john who??
evenin peeps...
anyone know whats involved in recaling a spedo?? apparenlty to get a gtr cluster to work u need to recal the spedo as diff ratios are different. Does that mean i have to take the whole car somewhere or just give them my cluster and diff ratio??
john hill of JHH Engineering
gotta give matty spryr a ring to see if he can do the tuning side and give me some advice..or if you have other thoughts who i should use?
well as far as i know, matt spry is the best, so many people have used him and i havent heard a bad result, so he may be a little more expensive but in the end u will have the best possible tune for the money u have spent there. and for the same power out put i heard he can increase your torque curb dramatically. so it will feel like it smashes u in your seat alot harder. one of my mates has a 33 gtst, with a power fc, bigger injectors, GT25/30 on it and it made 347rwkw, and man that thing is just unbelieveable aye, just smashes u back in your seat. he's coming on the cruise on the queens bday one.
evenin peeps...
not sure hey, as far as i know thery will just redo your speedo and recalibrate it, but i dunno how they work it out with the diff thing....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
