the V35 update model due later this year....:)http://www.prestigemotorsport.com.au/modul....php?storyid=25
hmm interesting...has similar lines to that of a 350z, any specs of it released?
hey daz
yeah i need cheerin up. came home to find a nice letter from QT containing another speedin fine (i also got done about 3 weeks ago when i was round dans place gettin my car looked at).
Still my gtr cluster got sent down from townsville so i got that aswell. Gunna plug it in tomorro and see what happens..
Hows the car anyway?? what was the damage??
hey daz
havent had a chance with all the shite weather to have a look, but i had a bit fo a look this arvo whenit wasnt raining, and the exhuast is hitting onthe hicas, and the sump gaurd is a bit mangled, plus the is a bit of oil under the sump area. so im hoping i didnt damage the sump, it isnt dripping oil at all, and the oil level is at 3/4 of the dipstick, so its either got a slwo leak or it was a bit low before i crashed.
the front steering is out of whack. so id say ive bent sum steering stuff. other than that i cant really see much else, but im no expert. here's hoping anyway.
yeah i got a gtr cluster cos i needed a new gts one, so thought what the hell. I believe the spedo will need recalibrating but everything else should work, as my current spedo doesnt' work at all its going to be an improvement either way.
work graciously informed me i'm spending 3 weeks in emerald soon, yaay for me...not :)
nice. my old neighbours movd to emerald. lol
anyway im gonna bail to watch this tv show on the abc. its pretty funny.
cya's later guys.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
