oh that'd be awesome, some DECENT money over there too, i've got a cousin who went over there and did some pharmacy work, he gets what he use to get over here, but in pounds, and doesnt pay tax on it (he puts it in an offshore bank account haha)
collector, thats the word i was looking for lol...i think her name is miffy? *shrugs*
hello karen how u doin
so your mums miffy? cos then i do know her lol
yeah good money, cheap nursing accomodation hopefullly full of cheap nurses :D
oh and hi karen :mellow:
no my mum isnt miffy, i was saying the supervisor of collections is miffy
haha cheap, english nurses *drools*...and all them english girls *drools again*
Also move around a bit, for instance
Its redcliffe lab this mon-thurs
friday st. andrews hospital
saturday- our central lab at murarrie
sunday - day off woo!
mon-fri - tugan lab (tweed heads)
sat - central lab at murarrie
next 2 weeks straight - toowoomba lab
no day off :D
Southport lab 3 days..
...the horrendous cycle continues :mellow:
varies, anywhere from 200 to 800km per week
last financial year i travelled 13000km for work purposes alone.
But say i drive out to stanthorpe, or emerald, bundaberg, gladstone etc.. i choose to use my car so i can claim the km and travel time for that too.
>>>>> And PHATBOI Has entered the building!!!!<<<<<
Moring MuthaFookers!!!
ha ha ha
back at work today!!
:mellow:
sleepin in this morning.. and trying to figure out whats a good mp3 player, bout time i bought one
sif waste money on something like that when u could put that money towards a massive turbo...or an Rb26...or or an Rb26/30! :D
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
