u guys been to the Jazzbar in toowong, the one that u get this extremely hot piece of marble (or what ever it is), a raw piece of meat and u cook it urself? my god its fantastic!
I wasnt happy either Karen! The Norman has turned crap recently :no: It is a shame too because it used to be the best! Now days the Morro and the pineapple are both better for steak!
The Morro is more exxy than the norman...but the pineapple might be worthy of consideration :P
I actually enjoy Sizzler steaks better...but the b@stards won't take a table booking :(
mornin anna-bananna :(...u good for lunch today? or u still feelin a bit under the weather?
i say we dont go back to sizzler unles they give us a table booking
hows the car karen, all fixed and looking even more sexy now?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
