I have one request though, as shane is keen to take me for a run in the R cause i cant decide which model to buy, Andy you have to take me for a run too man
Okay
Oi !
:D
lies :P
See how ansty they get? They know it is true
Do either of you two even remember what it is like to turn the key of your car and hear it start?? :P
yeh better go in andy's first, caus you dont wanna start of in a fast car and then go to a super slow one :P
:dry:
Oi !
:P
c'mon scuba schteeve! you know it's true :D:dry:
It can be done in a day.... easily! Well you know it's still hard wrok, but time won't be an issue, I don't think anyway
ps.. you will be eating steak at 7pm covered in grease still! It takes at least a week to clean up the last of htat shit!
*koolaid voice* oh yeaaaaah!
Bye Annaaaaaa!
ciao little fella! *pops turdy in handbag*
Shane think i am leaning moretowards the 32 hey, just cant get away from that look they have when you put mofo big tyres under them
they certainly do have an aggressive stance dont they...my suggestion you, buy a cheap one and get the engine rebuilt, or buy one that already has a bung engine...or buy a recently built one :dry:
ha ha cool! Well that hogs breath is used to us making a scene there...hey Liz?
GTR?? Cause GTSTs are poo with the RB20
Yeah i sort of wanted to get one with lowish K's but...but will keep it in mind.....However if i do get for only 20K and i have budgeted for one thats about 36 (simon from SVI reckons ill need this much for a low K V-spec 2) i reckon i could make it go ok for the rest
there are good things about GTS's but such as 2wd, sideways is always good
oh dear... *sigh* get yourself a GTR... then you'll see how very sideways they can be :P
Alright, I really AM going this time. Bye :dry:
oh dear... *sigh* get yourself a GTR... then you'll see how very sideways they can be :D
Sounds like you wish you guys had brought a GTR now?
I know it sounds like i want to thrash my car but after waiting so long to get one i dont think i will wring its neck too many times
See ya :P
Edited by SLO-89
u'll say that at the start, but then the bug will bite, and it'll bite hard!
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
