a good old kick up the rectum woulda done the trick darren, woulda saved u the effort of bending over and picking him up :laugh:
As of tonite, it's getting closer to me not being able to make autosalon :unsure:
he doesnt move he just moves into another corner then lies dead on the ground lol
autosalon was so boring last year i went, i went both days bcoz a few mate's of mine had a stand and there cars there, after about 1 hour u have seen almost everything in the place and u stand around waiting for the dyno comp to start that takes like 4 hours.....
im gonna keep my money this year i think.
