Gotta love "family leave" :( because blake has school sores, he cant go to day care, and because we have no immediate relatives who can look after him living loccally I have to stay at home and look after him, lucky the uni gives me 5 days as "family" leave PLUS my normal sick leave ;)
Loving it!
Gotta love "family leave" :( because blake has school sores, he cant go to day care, and because we have no immediate relatives who can look after him living loccally I have to stay at home and look after him, lucky the uni gives me 5 days as "family" leave PLUS my normal sick leave :P
Loving it!
I expect to see whoring then...and plenty of it ;)
Hope Blake gets better soon :P
How's Nell and Kayla?
sooo... will your car be ready for autosalon or are you gonna tow it?
definately won't be running, but it'll be towed. it'll be without injectors also as greenline is down and they havnt sent the injectors yet.
I expect to see whoring then...and plenty of it :(
Both good, how's "the boy"?
Meh I got better things to do than whore, I got a whole backyard full of mud which I'm going to go out and have a mud fight with blake ;)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
