OMG anyone heard of a place called big chief? they do burgers that taste like hungry jacks ones, but they're like twice the size! had some for dinner tonight down here in tweed heads.
argh ok. any reason?? for work or u just wanna go over there for something to do....
both actually, working holiday visa is good for 2 years, i get paid in pounds what i currently get paid in aus dollars for the same job, i get to travel, stay in cheap hospital nurses accomodation (filled with cheap nurses maybe? :( ) and generally will drink, stagger and sleeze my way through europe for a while per the traditon for alot of mid 20's aussies that go over there :(
cool wish i could come lol
haha slip me $50 and i'll get u on the plane as luggage, the rest is up to you :(
but on a serious note its something i think i need to do. I got nothing really keeping me in aus, so why not make the most of it :( I would hate to get to 40 and look back thinking i wish i had done it.
yea for sure man.... i wana do all that as well
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
