leaving that kinda thing in the staff fridge isnt recommended.
since i didnt want to take it home with me friday cause i left for indy straight away, i had to hide it in the fridge.
well, the freezer was the only option cause no one doesnt really go in there.
hahaha true true...mayeb tempt fate and microwave it? :)
nahh, all good. just left it on the window seal here for 5mins and that helped.
afternoon sun shining into the office here with no other buildings blocking the sun can come in handy i just noticed.
othertimes, the blinds do its job :banana:
you know what i just relised......
it might not be my turbo......
my little bro just said "Lee, U just got a package delivered at home......"
hmmm..... it could be "those" DVDs he he he
soon......
i will see it but Yay!! :)
i dont mind if its either ha ha ha my hands are gonna be busy this week end
on another topic......
those "kids' in the crash at byron..... have they told the cause? wasn't it a "high Powered" Commo?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
