got any reason why u dont like them? i've had no problems what so ever, and the speeds are fast, no dropouts etc...plus telstra is going down the plughole
optus run all the old network equipment from their overseas office.
they've not upgraded any of it in a while since they set it all up.
telstra on the other hand have a major deal with the big players including cisco.
they've recently just upgraded most of their exchanges for cable in launch of their new braodband network they are about to release that'll be apart of the 3g network.
SHHHH. no one is to know about this. :P
interesting...so what are the speeds going to be like? is it going to be reliable? what sort of cost are we looking at?
the US have had T3, T2, & T1 for years, and we're just getting T3 now, quite sad really
America is practically the backbone of the whole internet.
They can afford to sell t1-3 links for $60-$80USD a month to people though.
Unfortantly, we have the degrading pipeline link between countries where we actually suck the bandwidth from.
links will be faster, prices will remain the same if not, only go up by probably $10 or somethin like that.
our telstra wholesale rep didnt give me much info except for wat i said now and before.
And what happens if you go over the 7G?
either they stop your internet (doubtful) or they cap you to a really slow connection like at dialup speed (so they say it is but really, its half the speed of dialup).
OR.
they charge you for extra bandwidth you use and still stay at the same speed you usually get.
Hey John, I really admire you in taking on the qld police with that stupid copper who gave you those defects, STICK IT TO THE MAN DUDE! POWAH TO TEH PEOPLE! FIGHT TEH POWAH!
hehe, thanks dude.
goin to take a while to go through the process of doin this
but as they say - things come to those who wait.
just got to take all this step by step and get my fines out of the way
which will then allow me to move onto the next step of showing the next judge that the fines i received from this cop shows that cops like this one are clearly handing out fines for no proper/real reason and that either
a) the law should be taken away from the police in handing out defect notices
or
b) lower the power of this law to police in handing out defect fines to cars that are defected in terms of bald tyres, lights not working, etc etc.
stripping this power will become a victory point for us "hoons" against the fight we have with the police.
g'day andy, wats crappenin?
Narting much!
You wouldnt happen to have a spare S1 R33 ignitor would you :P This whole swapping the good one between cars is getting annoying lol
Morning Shane, Andy. *tips at*
Howdy
That is some funny shite John!! And being in Bathurst they probably had a line 10 deep for the position!!!!!
SIF bathurst is a sausage fest, you would be lucky to find 10 women on the top of the mountain
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
