God? :blink:
or that nice man you meet at the park who gave you candy and wanted to show you sum thing cool.......
yeh, that man in the park... think his name was eddie.
ewww! i was blinded for a few hrs, then this absolutely hot chick walked past and the blurriness went away.
a sight i'd remember forever after seeing her compared to that other thing.
john when will u learn mate? u have to shut me down with gay comments, is it to make up for all the women who have shut u down due to akward blinking and slight speach impediments or the fact they find you revolting??
hahahah, whats that, waited naked inside the door with ur cock in a jar of candy, then when the kids come, you just say, help youself and then giggle while they lightly brush ur member while grabbing the candy..
i love halloween spirits.
WHERE THE HELL DID THAT COME FROM.
i only see engage as the dumbest person here though.
:blink:
im starting to get tired of him and the fact he cant face me face to face like a man, u know what u did was wrong john and i have a few other people i know who have occured similar situations with u that want to see u aswell.
i think until you actually get over yourself and learn the real facts for yourself as well, you might understand a few things in real life. but until you let go of the fact that your not with that girl anymore (even though you go around saying shes your girlfriend), you got some serious issues to deal with.
ohh btw, your father is a lawyer right?
You wouldnt mind passing on his contact details then so I can get some legal advise from him, would you?
Wouldnt mind asking about those sladderous comments you made yesterday.
Ohh and also the threats you've PM'd not just me, but many other people on cruisingbrisbane.
ohh, while i'm at it, i`ll also ask him about the laws of sexual harassement from you towards the girls you've helped worked on there car and then in exchanged, asked them for sexual favours.
You may want to also explain why you've been banned from cruisingbrisbane forum 3 times under different nicknames as well?
ur obviously a waste of time, someone so thick and deluded. ive seen the pms u sent her, the sms, i also spoke to 3 people off this site and they said the same thing, one female using the words "he needs to be eliminated" but its ok john, ill leave u to bask in ur own lies but u will see me real soon.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
