yes yes...
Oi! don't go insulting shane. I will stick up for you in any regard when it comes to f**kheads that treat women like shit, but I will not stick up for you if you start shit with shane...
awwee i feel loved :(
Now now shane, he is a member of the high rollers, so he got alot of power, :)
it's in pieces now bryn :blink:
c'mon fellas, this is a fight that has been going on and round and round for months (more than likely years). This is not the place for it, please sort this shit out privately.
awwee i feel loved :yes:
it's in pieces now bryn :)
:blink:
BTW morning anna-maria :yes: :yes:
all excited about ur trip to NSW?
Hi shaney poo!
My ex's name is shane. he was a royal pole smoker. everytime I see you I think of him. I hate you for that :(
But you know I don't really hate you. Why didn't we do lunch this week *cries*
Yes i'm looking forward to our trip! We leave tonight. And I booked us into Amora in Sydney City for Saturday night, some new 5 star joint for bargain cheap prices cos I only booked yesterday :yes:
How are JOO?
Hi Anna, Shane, Lee, John, Bryn.
Only want to say one thing about the situation i just read on the last 4 pages. He must feel pretty tuff and proud to threaten people like that over the internet.
shhh
buy our car!
he can only sit behind a screen and threaten people.
but because i dont go out to cruising hotspots anymore on a thursday night, he thinks im running away from him!!
bawahahhahaha.
seriously, got better things to do with my thursday nights then go to a hotspot and get my ass raped by cops for no reason. already dealin with one set of bullshit fines, dont need anymore right now.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
