did u consider SK's package? they include custom spring rates, valving etc. those tein's will be 'setup' for roads, so the spring rates & valving wont be 'desirable' for the track, compared to those of SK's
u think they are mine? LOL i wish i had $8500 to spend on suspension :D
i'll be going for a set of these
bit under half the price, but will do more than what i want!
WTF are they??
shuttup andrew you already have enough shit. you're already replacing the radiator, cat, turbo and getting an oil cooler. no more!
AND I'M SO SICK OF HEARING STEVE FROM IKEA. HULLO! NO f**kING HULLO! *stabs*
Just the cat this week! I was going to do the reaiator but meh I want to do it properly
and then he'll be breaking diff's, axles...:D
Hopefully in A RWD the Tyres take the punishment and not the good stuff!
If my mechanical diff breaks I will be upset
dont know which ones they are.
Just told me they are street and track type suspension and are the ozzy ones...
Kit Part Number QSN64-EZSS3
They are being gheys
I think all the aus ones are a version of super streets
WTF are they??
wtf? no no no you're not! If you don't replace it before the track then I will! It's going to be fixed, i'm not letting you thrash that car with a busted radiator, I don't want overheating issues again!
plenty of bootspace daniel... *runs an hides*
The boot of a 33 is surprisingly comfy... pity you have it :D
WTF are they??
DMS, Drummond Motorsport Suspension. Bee's knees of suspension (for trackwork), under Ohlin's :D
Its already got an aftermarket diff? :D
maybe you could ring them and find out a bit more for me?
im not exactly right into the suspension bit as i just learn things as i go, so therefore, whatever he tells me is not fully understandable as he didnt take the time to explain it all to me.
number - 3892 9000
person talkin to me about it, i think his name is darren from memory.
well i'll gladly swap, just so u can be happy :D
number - 3892 9000
i rang fulcrum awhile ago when i was sorting my suspension out. they said the shocks (the ones ur looking at) are just super streets re-springed &/or re-valved to suit australian roads.
so in theory, they would be of a lower spring rate (softer) after they modify them.
I aint Buying the Just Jap one! So I will just get the spare one flushed at a proper place then wack that on
Yeah it is after market fo sho it is too consistant for a viscous and it makes clunky mechanical noises, plus my gearing is very obviously shorter :laugh:
number - 3892 9000
Im not great with it either, just make them explain it to you properly? EG how adjustable are they!
number - 3892 9000
They're never gonna take the time to explain it to you. That's why you need to know what you're buying before commiting to it. Andy has picked up some great deals just by doing a bit of research beforehand (HPI, SAU, google etc) and then asking around.
Hrmmmm... nah! You can keep our poxy 33
Your'e game man!
Sorry, couldn't help myself :D
Bingo
I was once told that Tien was the sony explode of the suspension world! Over Hyped but actaully pretty crap...and they had shock dyno evidence to back it up! But I cant say cause I have never owned any!
righto
wait, I didn't mean KEEP it for good... just for now :D
its 16 point adjustable... if u get some computer thing to adjust it, its then 32 point adjustable. dont know how that works out but yeh, thats wat he said on the phone the other day.
also these were the ones dan (3lit3_32) was goin to get me if i ordered them through him and dan knew what i wanted them for.
Poxy? And you want me to buy it?
It is poxy... in comparison to the 32 :D
It's all good! I hate spelling anyway and my grammar is not all that good either!
I can tell :laugh: ahahahaha I'm just bored is all :D
The temp is talking to herself again. This time about sneezing and saying 'bless you'. But she's saying it to herself! "Julie, I know when you sneeze you say bless you, ooh bless you Julie, thank you very much now I know this piece of cake should really be eaten but I just don't know *sneezes* oh bless you Julie..." :D
And the other chick in my section is pissed! She had a long lunch and came back off her guts. So she's sitting here watching youtube pissing herself laughing.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
