true true.
got a lil bit of work now, i've been doing nothing for the last week and a bit. gotta walk back up to the car to get a card with a number on it i left this mornin *sigh*
Skyricer’s need to take a lesion in lowering a car! You all have so much gap clearance between your tires and guards haha.
Example, lowered LXU55 more, and put some more preload on the springs,
30mm seal clearance, not low enough
25mm Exhaust clearance
Got the sump to sit up around 20 – 25mm
Front bar still looks way to high at 40mm
Paint and decent rims are overrated
Still looks like it has a lift kit :) Had it lower, but the top control arms fouled up on the strut towers and we hadn’t even let the car off the jacks!! Need to do some custom work before I go lower :)
Cant you just fit a lower front bar?... or let your tyres down :whistling:
I’ll throw on a full kit at some stage. I have rough dimensions for a kit I like, and it’s going to well and truly scrap along the ground. It’ll look awesome parked, highly impractical however.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
