do us all a favour dude and f**k off to another forum where you'd be more welcomed then here.
get the hint though, courtney isnt ur gf after talkin to her about it and after she's had a go at you about it, you still countinue on to pretend she is your girlfriend.
seriously, you need help.
go create yourself another account on cruisingbrisbane and get yourself banned.
You know when i was in Uni i knew a girl who had the same problem.....
she was hot and everyone new it....
there was this little dude who would constantly hang around her all day pretending to be her bf and when i asked about her he told me he was her bf.... being the rude barstard i am (Plus i really wanted to tap that ASS!!) I proceeded to pick her up, found out he wasn't her boyfriend and the lil bitch cried when he found out what she said, he started rumours about me, so i bashed him... the problem was i didn't get the girl but i still got to beat the shit out of a little big mouth spineless prick ha ha ha
i don’t know the point of that story but.....
HA HA HA you read it!!!!
:wave:
Afternoon all
Did i mention that i am sick of my R31 yet? WELL I FARKING AM!!!!!!!
Just dropped it off to get fixed, decided at luch time that it would drop its water all over the ground, so now its getting the injector done and the exh manifold leak, and hopefully that will be the last time i have to spend money on it until i get my R..........ahhhh GTR....Hmmm thats much better!
:wave:
Hahahahaha Nice.
:wave:
I want my minute back.
:wave:
HAHAHAHAHAHAHA......Gold!
Afternoon all
*waits for squizz's reply of, Buy my car*
woo interesting reading...
HUGS for all :P
boiya! feelin the love :wave:
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
