Why do you do this to yourself.... :rant:
*shakes head*
because it's funny...and i've got a working car thank you :dry:
hmmm... i wish i could acutally say "at leats my car drives!!"
But it doesnt :(
Till next monday!!!
karen, thats another reason why :whistling:
LOL
I can honestly say I have never been booked in my skyline :)
so w00t for me :whistling:
that's because marc drives it most the time :rant:
yeahs its amzing how fast 2 months have past, feels like yesterdat i was still drving :(
is that maybe because u did actually drive yesterday? :dry:
ok, i'll start taking bets on how long it is until u lose it again...starting at $5...
:whistling:
well i went on 1 point good behaviour on 20th of november 2004, and then this, so i give it another year til i do it again, BUt, i will be on opens, so i gibe it another 2 years :rant:
