Cool, Just been rethinking my stratergy tis all. Want to buy a house soonish so was thinking that maybe i should just get a GTS-T and get an R later on
Ahh I see GTRs do tend to be money pits
andy's car is for sale...
Indeed it is. And seriously it is in very good knick especially in the mechanical department! Except for the clutch wich we will have to fix this weekend!
Yeah thats why i asked for a pic.
Just not sure about the whole wine red thing tis all
when it is a all brown and crappy uncared for colour it is really gross, but if the paint is in good nick it is actually a really nice colour
Yeah and seeing as how it may need a rebuild after purchase, plus the whole insurance thing just cause its a R, would be better off waiting till i get the house and by then maybe get a 34......big Maybe but.
Does it have many after market bits? if any?
what clutch you putting in it?
Yeah but i have also seen so many of them its not funny
bloody oath it is a lovely colour! after the attention i've given it, the paint is really outstanding! i was amazed how good it looks. its even better now than how it looked at autosalon andy! (and it's still only got 1 coat of wax :D)
When you get some pics shane can you e-mail them to me please? [email protected]
Hey shane
are you free sumtime in the next few weeks :D
Come was and detail my car for me :)
It has turbo back exhaust, HKS intercooler, 18 inch wheels, Ummm some random sterio wich I am thinking about replacing, front and rear strut braces, and it will come with an uninstalled AVCR, It also has a GTR Grill and wing
The clutch going in is an exedy HD
Down here there isnt that many? White and black are by far the most common, closely followed by silver
Some times when it is clean I say Damn that is a nice car I really want to keep it!
HI5 Shane :D
sure thing
Hey shane
Come was and detail my car for me :D
next few weeks i could do it but it'd have to be at my place caus my weekends r going to be busy as up until SCC...plus a proper job takes 2 days
HI5 Shane :D
You ever had it compression tested?
So a bigger turbo injectors and power FC and it would be sweet
You aren't the only one that's washed her you know :D We used to take extremely good care of her, but she was stored in a boat shed for 6 months and was only used for emergencies.
When she's clean, she truly is an exceptional looking machine. The paint is so clear and vibrant still, it sometimes amazes me.
Nah never compression tested but that can be arranged, But I wouldnt expect any problems, it has been on stock boost its whole life
I would buy suspension first...then a power FC and see how you go with that! It is already alot faster than the R31 :D
That wouldnt be hard, i alost reckon i could run faster than it at the moment.
Yeah just looked at the pick that Karen ut up......Praise the raised!!!!!
I dont want it to be too stupid, if it runs mid to low 12 eventually ill be happy
did u ever wax it? noooooooo :D
I would buy suspension first...then a power FC and see how you go with that! It is already alot faster than the R31 :ninja:
compression test aye :) (ask again tomorrow hehe)
AND GET A DIFFERENT MUFFLER...the one on there now sounds soooo ghey! :)
but yes, suspension, brakes (rotors, pads, fluids & brake stopper) & FC will make it damn quick...then go get bigger turbo, fuel pump & injectors later
a mid 12 you could do with one of Slides turbos they cost about $950 and you can sell the turbo already on the car
So power FC and Slide turbo...low 12s becomes a bit harder
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
