i got it purely for the factor of looks
but also just another reason for cops and qld transport not to be able to defect me for it.
though, qld transport said its fine, cops may fine me for it because its attached to the pillar.
if it was attached to the dash board, then thats fine.
makes no sense cause its still in the same place if its attached to the dash board or pillar.
ghey!
Obstructs more of your view??
ghey!
I thought anthing above the line of the dash was going to attract some attention...like where your AVCR is? This will look heaps better than on the A pillar anyway....a pillar guages = ghey ++++
and i'm sure the clothes u brought were for 'look factor' too right?
not just somethin to keep you warm and covered up?
lol :P
I dont understand why women insist in covering up!! :P
its got to come under the height of where that arch thing goes over the centre gauges (speedeo, rpm, etc).
avcr is messured exactly same height as it.
got one of those bubble things that you can check if things are straight.
lol :P
ahahaha purely for practicality. You know me. Sif be clothed when you can possibly be nude :):P
Jesus christ shane.....How many did you email me?
none, hence y i posted them here :P
nah they are all ~800kb and it was easier to post here than to send u multiple emails, plus u can just open them and save them :)
15mins and im outta here.
woohooooo
haha sucker :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
