OMG wanna know what I :P about our 32???
Doesn't matter if it's filthy or clean... it still looks bril! And I love how the front rims look darker than the rear ones, even after 1 day of driving :P
Might have to give them a call. Try and get me out of the shit.
Hey Dan, my suggestion is to go for a loan prior to finishing up your current job, otherwise while you're on probation, you probably won't get an approval.
whatever u do! never take out the back seat of a r33 skyline.
the amount of greese behind the back rest bit gets all over the seats.
Grease...I guess I'm lucky that I don't have any muck like that in my car.
Actually Marc discovered when he put the sub in, that the carpet in my car has NEVER been pulled up before, coz its still stuck to the floor of the car body :P
Nice pics Shane :)
and they dont do justice to how the paint actually came up! u can see the glitter in the paint its soo purty :P
Yeah will save them at home but
just remember the page number and go to it when u get home
still waitin for the guys to get your site back up.
damm storm.
awwee poor didums :P
i cant imagin why the carpet would need to be pulled up except to be replaced
other then that, possibly drug runners storin drugs under the carpet for there deliveries?
lol
unless u got some good stuff to get it all out, then have fun :P
Mine had no grease...I sometimes wonder where the hell they found your car!
How many k's Andy or Anna?
Around 65 somthing k
lol
To run the sub cabling from the rear of the head unit to the boot...its called being tidy with an installation
lol, did you run yours under the centre console area, under that centre storage box thing and under the backseat?
lol, did the same with mine too. was a bitch of a thing to get that carpet up. so found a metal pole that was hollow and reamed it under the carpet and put the cables through the metal hollow pole.
worked like a treat!
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
