He has money...you loose
*shrugs*
Where to get suspension from? is the next question.
what do u want to use the car for? how much do u want to spend?
answer those 2 questions n then i/we can give u some help :D
lol......Not yet i dont but hopefully its coming
I should have said when it comes down to it you will have money
3 letters H S D I can even help you out with a good price if you like
Yes that is probably better.
Cool is that what you run in the 32?
I want to do a bit of track work ad some drag, but mostly street.
just do wat i did and get some Fulcrum Tein coilovers.
shane and me did mine on saturday.
way better then standard suspension and the handling is far better!
yeah i got some qein coilovers and they are awesome!!!
(although dont have much to compare with)
well daniel heres some to think about:
DMS (Drummond Motorsport) - Top-o-the-line track suspension $4000
Whiteline & Bilstein - Good quality track suspension, can also be tinkered for drag ~$2000
HKS Drag coilovers ~$2400
TEIN - allround stuff ~$1800
If the funds can stretch, i'll be getting the DMS stuff in the new year, but if they won't (and if i cant wait) i'll go for the whiteline & bilstein stuff
Nah that is what I wish I ran in the R32
Way over priced
HSD you can pick your spring rates so you can make them what ever you like! I saw some shock dynos of them and they perform alot better than those other green ones :D
I WANT A STICKER DAMMIT!!! *me stomps*
and all i want on it is the SAU logo!!
and i want it now!!!
We have 4 at home. Got them in our membership packs, and Andy doesn't want them on the cars. You can have 'em if you like.
that reminds me...I need to raise the rear of my car! The new cat changed the angle of the exhaust and now it hits everything lol
yeh it sucks. 5 seconds of normal driving followed by 'scraaaaape PING!'
YES PLEASE!!! PM sent!! :no:
yeah its the worst sound - luckily i only get it going in and out of driveways
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
