isnt house work for women ?
i mean umm ummm girls are neater and like things perfect?
Nice save... :)
Is ok i know what u mean.......women should stay in the kitchen
O RLY??
but i should add after they complain they end up cleaning up my so called 'mess' anyway.. next step will be to coax them back into the kitchen to make me a roast dinner. 1950's society FTW!! :huh:
Hrm, well if men earned enough money to keep women in the style to which they can become accustomed, then yes I'll go back to teh kitchen and not go to work everyday :D
Oh and evening all :)
bah! stupid friggin greyound bus company! i waited for ages for the 11:40pm bus as i had urgent bloods to sent to brisbane.... it was a no show! :huh:
anyone still up at this hour?
tell ya what tho, theres some fine female talent out on the town here in bundy... must be the light that hides the buck teeth and huge arms, or maybe i'm just getting despirate :huh:
oohhh fancy!
stupid name for a club tho.
agreed...there were these 2 hot birds at the wedding, who i didnt have a clue who they were, they came alone, and left alone, was weird :D
i had a nice steak for dinner! the place i'm staying at has excellent food :) and a minibar :huh:
damn u :)
hmm maybe the strippers for the bucks party got there a bit late :huh:
last wedding i went to was a real bogan wedding, done in someones backyard - but they had commercial fridges FULL of VB haha we all got pissed then went to the casino, then a strip club
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
