Sticker??? Did sum one say stickers???
can i get sum stickers!!!!!
Lee, yours got posted too.
I was only given 26 in the first batch and those people that have been waiting the longest get theirs first. More stickers are being made right now!!!
Nah, I don't think my wedges would stand up to well to a bucket of oil. The sneakers were fine, I gave em a quick wash with solvol hand scrub, rinsed them off and because they are black to start with, you can hardly tell :O I really should nappi san the laces though. Poor hello kitty isn't pink anymore!
Am so :rofl:
Hey did you get the flywheel machined before putting the new clutch in?
andy had a separate clutch and flywheel ready, and that flywheel was in pretty good nic :O
but yes, whenever i do a clutch, i always get it machined
you know how i asked you to do my clutch, how much is your time worth? Carton of Beer? Bottle of Johny Walker Black? he he he if your luck maybe Blue lable?
shane about thoose cluch bolts where do i go get them from? prolly do the clutch and fly wheel in Jan....
should i buy a Needle roller and High tensile Pivot???
STICKERS!!!! YAY!!! :rofl::no:
:rofl:
shane... check out the pics?
certinaly did, awesome pics once again mate :wave:
Awsooooommmeee!!!
I am so over this Job!!!!
one little niggle i've found with the car, the steering. it tends to pull pretty badly and easily if ur driving on roads where there are ruts where the wheels have worn the road down. also the steering wheel isnt dead straight. a simple good wheel alignment may jut do the trick.
P.S that muffler still sucks major ass :no:
depends if i cant get my mates hoist ill have to do it on the ground again, and then if the box wants to play ball when it goes back in :wave:.
NISSAN, what car, engine & gearbox is it for? ill make a call
all u need is a new throwout bearing (which should come with the clutch), no need for a pivot, and wtf is a needle roller :O
P.S that muffler still sucks major ass :O
Thats the down side of 17 and 18 inch wheels they follow the road pretty bad
:O
certinaly did, awesome pics once again mate :no:
P.S that muffler still sucks major ass :rofl:
Yeah it needs an alignment big time wich I will be doing soon, also wider wheels with low profile tryres means tramlineing...the R32 used to do the same thing when it had those wheels, the price you pay for having sexeh wheels
HI5
PS the muffler isnt a rice cannon that every man and his excell has, it attracts no attention and still flows the same due to the fact that the cross section area is the same as a large tip....if it fitted the R32 I would have swapped in an instant, the R32 one shits me no end
ohh yeh!
got to get new tyres this wknd too!
anyone know of anywhere good thats open on a saturday to get a good set of tyres at a good price?
Kieth 4 Wheels Springwood
Being my stepdads brother has a bit to do with my response, but he is well priced
HI5
Not after a rice mobile....just purposeful
ohh yeh!
Tredz international
I got bridgstone tyres in pretty good nick for $80 each
Where as new crap nankangs were going to cost over $1000 these prices are for 18s but
But tredz dont fit so you will have to book someone to fit them too
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
