Morning kids.
Apparently that noise is an 'instalation error'. He said the thrust bearing is poking through the clutch cover. I don't know what this means, but you obviously will :happy:
weird clutch noises are all gone now and damm it feels alot more smoother to drive to.
still grabs hard but cant actually feel it when riding it as much.
P.S HARDCORE SUCK MAJOR ASS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
f**king wankers didnt do the job properly at all on the car.
dan was telling me all the shit they did wrong last night.
they didnt even replace the gasket
and they've done a dodge job on all the washers.
plus they didnt even tighten up any of the bolts to the manifold. they were just done up finger tight.
Morning kids.
Apparently that noise is an 'instalation error'. He said the thrust bearing is poking through the clutch cover. I don't know what this means, but you obviously will ;)
noooooooooooooooooooooooooooo *cries*
gearbox out time...again :happy:
i didnt check the bearing on the box side, just pulled it down out of the road and just assumed it'd all stay in the right place, i guess i was wrong :D
i didnt check the bearing on the box side, just pulled it down out of the road and just assumed it'd all stay in the right place, i guess i was wrong ;)
Haha i hate having to pull a gearbox out for the 2nd time
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
