yeah ok put another doctor back in his little box and worked whilst thinking about my 33 and the 260z I want lol
Get a 240...so much cooler looking! Either way both are better then 280 :vomit:
KIT KAT COOKIE DOUGH BARS FTW!!!!
PS I HATE YOU
yeah I have found a fully restored 260z for sale in pepper grey and the price is quite reasonable, I have no real issues selling the 200 for it as I love the look of the old z's
ohh nice pic, i want a rc car but they seem to cost too much, are electric ones any good for just mucking around with or should i get a proper gas one?
Get a hotted up electric, mine go hard.
so wat was that boost problem?
and if u dont mind telling, what did it cost?
P.S im sure theres ppl on here that coulda done everything for u minus the tuning for alot less ;)
combination of wastegate actuator and turbotech boost controller bleeding off boost (i looked at the dyno reading)
umm it was more than quoted but it did include replacing all exhaust studs and a new gasket which wasn't cheap, plus a service i wont say the exact amount as it wasnt astronomical, i can send you a pm if you wish?
and if you're referring to dan he couldn't help me at all cos he has too many jobs on his hands already.
man i'm glad i didn't get a bigger turbo tho, its a pain driving it as is, i want response darn it :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
