sif send email then go out :D
;) I'm so sad now
Awwwww :D
if u want a decent job, we cant do it caus with 2pac u need to do it in a spray booth (i looked into this all yesterdya for my car ;))
2Pac is very carcinogenic apparently, hence the requirment to use a booth ;)
A certain somebody may have taken a phone call regarding what scope there was for being granted a water licence in the gatton area......the interesting thing was when the question of what the water would be used for was asked the answer was.................................Facilities at a proposed racetrack :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
