if u have problems with companies these days and need telephone support and know there call centre is in india or somewhere of that nature. go to there store and talk to someone who is able to speak english and if telephone support is then needed, make them make the call and talk to the operator :D
or just give up altogether and change companies!!!!! :)
Mangrove Jack?
they must've come down in price if so.... last time i looked they were around $120 for a fingerling
$120!!!
who wants one........
I'll go and throw the cast net in this arvo and see what I come up with.....
little barra
baby mangrove jack......
all sorts of cool little fishies....... :)
maybe if u take it to a tuner that knows what they are doing?
lol but seriously, whats wrong with it now?
Arent you using mercury :)
My last tune was done by one of the best in Sydney, it is good and the frist lot did an amazing job since they tuned it with an air leak the size of a 50c piece!
Not sure what is wrong, but it surges under load, maybe the clutch needs rebuilding (I bought it with not alot left on it), Maybe the turbo is broken or too small, Maybe the leaky gasket is causing it, maybe there is a restriction somwhere else in the exhasut. It is going to ba annoying that is for sure
yep i certainly am using mercury, and they are looking after me quite well :mad:
I can't see how the clutch could make the car surge under load, if it was stuffed, it'd be slipping. Like i said, take it somewhere and get them to have a good look at it. Tell them what's going on with it, and get them to check it out. and change that bloody leaky gasket, u lazy ass :D
yep i certainly am using mercury, and they are looking after me quite well :)
I can't see how the clutch could make the car surge under load, if it was stuffed, it'd be slipping. Like i said, take it somewhere and get them to have a good look at it. Tell them what's going on with it, and get them to check it out. and change that bloody leaky gasket, u lazy ass :)
If it is only beginning to slip it could have surging effect, eg it grips and slips periodically
I really hate those bolts at the back of the turbo...im not doing it again some workshop can do it I have taken that farking thin off about 5 times this year and I am over it lol
I want this for my "drive to gatton and carry stuff that the skyline can fit" car
How wierd is it
just brought some GANADOR STYLE review side mirrors for the car :)
goin to get some nismo clear side indicators this wknd
should bring part of the 'exterior' look up to what i'm wanting.
got a bit more to do though :)
ahh yehhh
that be flash eh brudda
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
