wouldnt have a clue.
the ghost place i know of here in the city is at the Kwick Kopy place here new qld transport.
head down stairs and you'll see this thing floating around in a blue gown or somethin like that i been told.
i wanna go check it out!!!
say if u had the opportunity to get a lease car and the price range u were looking at was $85 000 MAX, what would you get? evo with all the extras? or something different
I was put in this situation when I was working.
I have a fetish towards NSX, and I wouldn’t mind an R34 GTR just to say I have one.. So out of performance cars those were in my top 5.
I had also considered a pimped out SUV, a lease isn’t really worth it unless if works for you tax wise eh.
its got to be classified as a "luxury" car though.
"A luxury car is defined as a car with a cost greater than $57,009. The cost includes stamp duty, delivery charges and extras (such as a CD player) but excludes GST, registration and third party insurance."
:wub:
P.S i suspect u got the email aswell john? :yes:
i'm pretty sure it has to be a new car. so what does that leave?
luxury cars here in the company are seen as anything over $57,009 which also includes the stamp duty, delivery charge and extras like cd player, etc.
hrmm, wonder if they`ll include a import and compliance fee into that price???
i'm thinkin a - Mines gtr r34 :wub:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
