he he he now you know what would be fun??
a whole page of REALLY BIG POSTS!!
but my work sucks, come Chrissi everyone else is winding down, me no i get even more work!!
Oh well.....
:) i dont have my car back yet!!
ha ha ha i raced this s14 last night in my little bros 33.....
beat him in 1st 2nd 3rd and 4th, stoped there but he kept going......
got done by the cops down the road from us.....
i was so lucky not to get caught :laugh:
only got pulled over for an RBT and Licence Check.....
Burgandy side mirros, black looks poor. Unless its carbon fibre i guess.
which looks better?
burgandy colour side review mirrors
or
black colour side review mirrors
pics -
sideskirts are on there way!!!!
the front bar stays as is. its a 400R bar.
best lookin bar i reckon - got that tough look to it. hehe
wait till you see the final outcome of the car.
i've had a photochop pic done up for me and looks f**kin tough!!
cf FTW!!! although it would look kinda out of place without a cf bonnet :)
yessssssssssssss :laugh:
hey fellas get a load of this pic. I did a clutch in a mates car last nite, and this is what i found when i pulled the box out. That furry looking stuff was all inside the bellhousing, and its the actual organic clutch packs from the clutch face :laugh:
Looks like mine, we had to pry it off the flywheel as it had fused its self on.
2nd gear, limiter dump and 10psi hahaha
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
