its taken me a few hours, but the house just hit 19 degrees, only 3 degrees to drop and im done
lol nice work. i'mdoing the same at my office, just it only takes 15 mins with industrial size aircon and ducting :)
i has fully ducting, and two MASSVIE (for home use) air con units out side, just takes it time :ninja:
this one is my favourite
http://freenet-homepage.de/dhpics/keeley_hazell/5.jpg
the bra could be smaller though
dude same photo but mines bigger :)
but i will tkae yours now cos then i can see it!!
wrong???
about the brunett thing??
no i was talking bout your posts not the other lee's
WOW thats a huge boob pic
i know :)
i know!!
where mike gone??
you think he's gettting busted for that pic before??
or is he off killing Kittens again....
no, not killing kittens. had a phone call, and got mars bar from servo. back now, no need to get stressed. i will still screw you all, just let me get ready first
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
